mkzwoo
Introducing the Bedroom Comp MkII: Your Dynamic Range Essential!
Elevate your sound to new heights with the Bedroom Comp MkII. With a perfect blend of VCA and Opto compression models, this plugin gives you precise control and an analog touch for a polished and professional sound.
Dual Compression Models, Singular Excellence:
Experience the best of both worlds with VCA and Opto compression models, seamlessly selectable in the Bedroom Comp MkII. Tailor your sound with finesse, whether you need quick and surgical or vintage and smooth compression.
Total Control at Your Fingertips:
Craft your audio with precision using adjustable Attack, Release, Threshold, Ratio, Input Gain, and Output Gain controls. The Bedroom Comp MkII puts you in charge, allowing you to sculpt your tracks with expert finesse.
Frequency Focus and Knee Flexibility:
Refine your compression with the integrated highpass filter for targeted frequency response. Plus, the Knee control adds versatility by modulating the relationship between threshold and ratio in a non-linear way, offering compression that behaves like an analog device.
Effortless Interface, Effortless Sound:
Navigate your audio journey seamlessly with the Bedroom Comp MkII's intuitive interface. Spend less time tweaking and more time creating, all while achieving a refined and professional sound.
Enhance your tracks with the power of the Bedroom Comp MkII. Elevate your audio production with dynamic precision and analog elegance. Try the Bedroom Comp MkII today, completely free!
Formats:
- Mac: Universal (Rosetta and Silicon) Audio Unit (component) and VST3 - 64 bit
- Windows: VST3 - 64 bit
- Windows: Download the windows zip file from this post, unzip the zip file on your PC, copy/move the resulting .vst3 file to your plugin folder. The default location is here: C:\Program Files\Common Files\VST3
- Mac: Download the mac zip file from this post that is in the format you normally use (component or vst3). Unzip the file and copy/move to the appropriate folder:
- AU (component) /Library/Audio/Plug-Ins/Components
- VST3 /Library/Audio/Plug-Ins/VST3
Bedroom Compressor MkII
Introducing the Bedroom Comp MkII: Your Dynamic Range Essential!Elevate your sound to new heights with the Bedroom Comp MkII. With a perfect blend of VCA and Opto compression models, this plugin gives you precise control and an analog touch for a polished and professional sound.Dual Compression...
viatordsp.gumroad.com
