Studio One 3.2.2 verfügbar
  • Ersteller drewsocial
drewsocial
Sehr schön, sehr schön! :right:
Version 3.2.2 Release Notes (May 19, 2016):
New features and improvements:
• New command to open Event FX window (Alt+F)
• ALT modifier for fades now suspends crossfade editing
• New option to enable/disable auto-expand layers after recording takes
• Monitoring button and metering reflect correct status in tape-style record mode
• Bus channel metering shown on automation tracks (track height “normal” or higher)
• [Project Page] MD5 checksum for DDP export
• View all channel types in inspector
• Use ALT modifier to add FX plug-in as bus channel when dragging to console
• Improved import of Cubase/Nuendo Track Archives (now supporting level, mute,
automation data, VCAs)
The following issues have been fixed:
• Mix Engine FX have no latency compensation
• Crash on quit with multiple open songs
• Controller data not visible while recording on Instrument Track
• [Music Editor] CMD modifier behavior for temporary Paint tool should be inversed
• Crash after drag and drop of audio to the browser
• Alternate range tool doesn’t work on automation lanes
• Paste at original position doesn't work for arranger parts
• Dragging multiple events to empty space doesn't create multiple tracks
• Layer name not set on first take
• Legato command misinterprets last event
• Bus connection lost after adding VCA in track controls
• Automation track to lane area not properly transferred on drag
• Wrong channel order after adding VCA from track controls
• [OSX] UAD plugins leave white boxes on the screen
• [Presence XT] articulation key switches not applied for notes on same time-position
• Impossible to set cursor to bar 1 beat 1 in Scratch Pad
• Vertical zoom state not reset on double-click when all notes have the same pitch
• élastique Pro 3 time-stretching out of sync in stereo files
• "Solo follows selection" doesn't work for shared instrument tracks
• Crash after undo audio quantize of grouped tracks
• Play Start Marker placed in negative time
• Delay Compensation broken for Pipeline on Main Out
• High sample rates not represented correctly in OpenTL
https://forums.presonus.com/viewtopic.php?f=213&t=18545
https://shop.presonus.com/products/software/studio-one-add-ons/Presence-XT-Editor
:-o
Nochema' 87 EUR für eine Editierungs- und Importfunktion im "Sampler"?
"Presence XT Editor unlocks the Edit Page of Presence XT, the built-in sample player instrument of Studio One. This add-on turns a great-sounding instrument into a powerful sound design tool for musicians, producers, and sound-designers. With direct support for all major sampler formats, it's the perfect host for any custom sampler sound library.
Import samples via drag & drop, supporting popular formats such as WAV, Kontakt (unprotected}, Giga, SoundFont and EXS24. Edit mappings, layers, and various trigger options. The assign articulations to key switches with just a few clicks. Then add additional realism to sounds with manual or automated sound shaping and sample playback variations using the powerful JavaScript based script editor and create effects like fret noise, key-clicks, or legato via scripts. In addition 8 assignable knobs and buttons are available as custom script controls.
Finished sounds can be saved as Presence XT presets or exported in a compact sampler file containing all samples, mappings, scripts, and settings for convenient file sharing and exchange."
Na gut ....
Naja, das Ding ist für Sounddesigner gedacht, die damit u.a. eigene Libraries erstellen können und öffnet den kompletten Unterbau vom Sampler, inkl. Scripting. Ist doch ziemlich logisch, dass das auch was kostet.
Sind paar gute Features bei und paar Fehler beseitigt, prima :)
Mix Engine FX hat nun Latenz Kompensation, die Ordnung der Kanäle bleibt beim Zufügen von VCA Fadern erhalten usw., darüber wurde hier im Forum ja auch diskutiert und paar Sachen sind mir gar nicht aufgefallen, ich wäre kein so guter Testkandidat :D
...kurze Frage: "Studio One zeigt mir noch PlugIns an, die sind definitiv nicht mehr auf der Platte, und auch nicht mehr in der Registry, wie bekomme ich die aus dem Instrumenten-Browser-Dingens-Baum raus?"
Thank you very Money (Leningrad Cowboys)
Das dürfte eigentlich nicht sein, denn normalerweise scannt ja S1 bei jedem Start die eingestellten Plugin-Ordner. Was sein kann ist, dass wenn man sich die Plugins in S1 selbst sortiert hat, also weitere Ordner angelegt hat, dass diese bestehen bleiben, obwohl kein Plugin mehr drin ist.
Zuständig dafür ist dann eine Datei namens "PluginPresentation.settings"
(C:\Users\(dein Benutzername)\AppData\Roaming\PreSonus\Studio One 3)
Diese könntest du mal löschen, aber dran denken, dass dann deine eigene Sortierung im S1 Browser futsch ist.
Du kannst "Reste", falls wirklich vorhanden, natürlich auch einfach im Browser ausblenden.
Du hast mir indirekt geholfen, DANKE!
...und da viel es mir wieder ein, hatte das Häkchen "Beim Programmstart nach neuen Plug-ins suchen" raus, wegen schnelleren Programm-Start.
...und siehe da, alte Enträge sind raus !
wow, das geht ja fast zu schnell ;-)
Jan
Can
danam
Introsong
TheSarge
TheSarge
Dimitrirec
Dimitrirec
Dimitrirec
