REAPER 5.30
  • Ersteller Tonminister_V2
Tonminister_V2
Tonminister_V2
Control surfaces:
- add customizable Web Interface, easily accessed via http://rc.reaper.fm
- do not prompt when recording via surface and no tracks armed
- bring project media online when inactive and starting playback/record
ReaPlugs:
- improve analyzer display in ReaEQ/ReaXcomp (increased range, better integration behavior, interpolation bugs fixed)
- resize ReaEQ/ReaFir/ReaXcomp to parent window
- optionally log MIDI meta-messages in ReaControlMIDI
Video:
- improve reverse item playback performance
Notation:
- add Note Properties to note context menu
- add support for double and triple dotted notes
- add support for tremolo ornament
- make all visible tracks editable by default
- enable various mouse cursors (copy, move horizontally/vertically, etc)
- fix lost notation data when editing while using MIDI filter
- fix mouse editing of manually positioned tuplet brackets
- implement arpeggiate mouse modifiers (same behavior as piano roll)
- improve default tuplet bracket positioning for quarter and half notes
- make it slightly easier to enter a note at the start of a measure
ReaScript:
- extend gfx.drawstr() to support text justifying and clipping
- add joystick API
- optimize execution API functions added by extension plug-ins
- improve function prototypes/documentation in watch list
- make Lua/Python known-function detection/documentation case sensitive
- run __startup.eel/__startup.lua on startup (hold shift to disable)
- update Lua from 5.3.0 to 5.3.3
- fix graphics overflow when scaling very large bitmaps
MIDI:
- prevent re-selecting CC and text events when moving notes via action
- fix selection/editing of selected velocity and CC events when intermixed with unselected events
- prevent drawing note names/velocity when notes are too close together
- set default shift+alt+drag mouse modifier to no action (to avoid conflict with default shift+alt+click to select all notes in measure)
- update editor display when recording into secondary items
- chase notation messages when seeking
Actions:
- add actions to insert or extend MIDI to fill time selection
- add actions to import or export track MIDI lyrics
Development IDEs:
- add support for shift+click text selection
- support load/save of color presets in theme tweaker
- open ReaScript help directly to the language currently being edited
FX:
- support on-the-fly Audio Units PDC changes
- avoid close/re-open of FX UIs in certain instances (fixes potential macOS Melda crash)
Project tabs:
- respect 'offline background project media' when restoring application focus
- add default option to force project tabs visible when monitoring FX are in use
Action list:
- add context menu item to copy action text
Big Clock:
- improve count-in beats-only display at negative times
JSFX:
LTC/MTC sync:
- add options to automatically stop recording on timecode loss and/or discontinuity
Lyrics:
- update Lyrics.lua to support lyric input and editing as well as display
Mixer:
- fix FX copy/paste menu items sometimes inserting FX instead
Peaks:
- allow bringing media project online while building peaks
Preferences:
- combine volume handle range preference with handle/knob preference
API:
- treat volume as dB rather than 1% of fader range in CSurf_OnVolumeChange relative mode
- add SetTrackMIDILyrics, GetTrackMIDILyrics, GetTrackName
- add MIDI_GetAllEvts, MIDI_SetAllEvts
- make APIExists() only return true for functions accessible via script (not C++-only APIs)
Download
Das Webinterface funktioniert prima.
Man kann den Reaper sehr schön über das Handy steuern.
Leider wird bei mir der Passwortschutz nicht angenommen.
Ist das bei Euch auch so?
Die Remote-Funktion ist wirklich der Hammer (ich hab sie ohne PW eingerichtet). Das erleichtert einem einiges. Vorallem muss ich nicht mehr über meinen Hund steigen, wenn ich vom Mic zur Tastatur will
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
mkzwoo
mkzwoo
mkzwoo
