ProTools 11
  • Ersteller schoeni
Status
schoeni
schoeni
Anscheinend kommt morgen PT 11.
http://www.guitarguitar.co.uk/recording-studio/detail.asp?stock=13040514563058
Pro Tools 11 sets a new standard for audio production, offering an all-new audio engine, 64-bit performance, expanded metering, and new HD video workflows, enabling you to take on the most demanding sessions and maximize your creativity—without holding anything back. Get multiple times the processing power of Pro Tools 10. Handle huge sessions and gain more memory headroom to go even bigger. And with faster than real-time offline bounce, you can deliver your best mixes faster than ever before.
64-Bit Architecture and new Avid Audio Engine
Get multiple times the processing power of Pro Tools 10 with the all-new Avid Audio Engine
Add epic numbers of virtual instruments and effects and experience performance like never before
Handle huge sessions with ease and gain more memory headroom to go even bigger
Get ultra-low latency with dedicated input and playback buffers on native systems, without sacrificing plugin performance
Maximize plug-in counts with dynamic host processing, which reallocates resources as needed
Get more accurate mixing and processing with time-stamped plug-in automation
Offline Bounce
Speed up mix and stem deliveries with faster-than-real-time offline bounce
Avid Video Engine
Play and edit HD video with the new Avid Video Engine—the same core engine as in Media Composer
Output HD video with many options from Avid, AJA and Blackmagic Designs
Satellite Link
Control multiple Pro Tools|HD systems from one with Satellite Link, now included (Pro Tools HD 11 only)
Workspace Browser Improvements
Accelerate and simplify audio file searches with the optimized Workspace Browser
Extended Metering and Mixing Enhancements
Mix with confidence with expanded metering, including gain reduction (Pro Tools HD 11 only)
Based on professional customer feedback – 16 new metering types in both scales and ballistics.
Monitor sends through new mini meters on every channel
Monitor gain reduction on plug-in Inserts through new mini meters (Pro Tools HD 11 only)
Work faster with new key command workflows and Mix window enhancements
See every session detail with full Apple Retina display support
Co-Install of Pro Tools 10 & Pro Tools 11
Comes with both Pro Tools 11 and Pro Tools 10 licenses for session compatibility and to help ease the AAX
transition, as our partners port their plug-ins to 64-bit AAX
Link ist leider tot...
Als ich den Beitrag erstellt hab ging's noch, jetzt anscheinend nicht mehr.
Text war aber der gleiche wie im Beitrag oben :)
Trotzdem danke für Info
Status
