News POWAIR v1.1 von Sound Radix
Update mit neuen Features und Verbesserungen
Sound Radix hat das POWAIR PlugIn in der neuesten Version v1.1 veröffentlicht. Das Update bringt nicht nur Verbesserungen, Bugfixes, sondern auch einige neue Features.
POWAIR ist ein neuartiger zweistufiger Kompressor/Leveler. Das PlugIn ist speziell entworfen, um komplexe Dynamikstrukturen auf “Power-Level” zu bearbeiten.
Das POWAIR PlugIn arbeitet mit allen gängigen DAW. Unter ProTools (AAX) und Studio One 3.x (VST3) werden die Gainreduction Meter des Hosts direkt unterstützt. Zusätzlich werden unter ProTools die Automation Key Modifier unterstützt.
Mehr Informationen gibt es hier.
Ein Auszug aus dem aktuellen Changelog von Sound Radix zu POWAIR.
  • Added peak clipping options.
  • Added user-definable meter peak hold.
  • Improved performance.
  • Added UI scaling (75% – 200%).
  • Limiting is now based on true-peak.
  • SCF – improved filter phase-response.
  • Pro Tools (AAX), Studio One 3.x (VST3) – support gain reduction meter.
  • Pro Tools (AAX) – support automation key modifiers.
  • Presets names are now being stored and recalled.
  • Bypass makes UI grayscale.
Fixes
  • A/B states were not properly stored and recalled.
  • Meters/Leveler did not clear state when playing after stopping.
  • VST denormalization-related performance issues.
  • Possible crash on Digital Performer (VST).
  • Input meter could show noise-floor instead of silence.
  • Various cosmetic UI inconsistencies.
  • SCF – possible crash when LF was set to highest frequency.
  • SCF – Solo didn’t work when the compressor was off.
  • M/S mode was processed in Leveler stage.
  • Fixes & improvements to auto gain compensation and side-chain compression.
  • Switching between Mono/Stereo instance on Logic X could lead to a crash.
  • AAX with side-chain could produce silence when rendered offline. (Commit/
  • Freeze/Bounce Offline).
  • VST3 might not work with Direct Offline Processing.
  • In some settings, dry signal could be not dry.
  • Possible crash when inputting out-of-range values.
  • Fixes & improvements to Windows installer.
  • The update is free for owners and can be downloaded from their Sound Radix account.
Hier geht es zur Release News vom November 2017
https://recording.de/magazin/powair-von-sound-radix.5009/
Lacunaflow
Lacunaflow
Lacunaflow
Can
Can
Can
Can
Navar
N
