HoRNet TreBande (Analog EQ) v1.0.0 x64 [FREE]
mkzwoo
mkzwoo
HoRNet TreBande is a meticulously crafted three-band semi-parametric equalizer that mirrors the character of the equalizer found in your average mixer. This free plugin is more than just an equalizer; it’s the heartbeat of your mixer’s distinctive sound, meticulously reproduced for precision shaping in a digital environment.
Embrace Mixer Nostalgia TreBande is more than an equalizer; it’s a homage to the classic, timeless sound of your average mixer’s equalizer. Rediscover the sonic charm of those mixing desks that have left an indelible mark on the history of music production.
Equalization Precision, Mixer Style Crafted as the equaliser section of our acclaimed Cassette644 plugin, TreBande brings the exacting precision of your average mixer EQ into your digital workspace. This isn’t just an emulation; it’s a faithful reproduction, ensuring that the nuances and tonal subtleties of your favorite mixer’s equalizer are at your fingertips.
Warmth and Saturation, Mixer-Style TreBande doesn’t just stop at precision equalization; it introduces a touch of warmth and subtle saturation to your audio. This characteristic warmth is the very essence of those classic mixer equalizers that seasoned engineers swear by. Elevate your sound with a gentle richness that pays homage to the analog warmth of vintage mixing consoles.
Enhanced Brilliance, Presence, and Bass TreBande mirrors the equalization controls found on your average mixer, offering control over the brilliance, midrange presence, and bass frequencies. Dial in precise adjustments with the High Shelf, Mid Band, and Low Shelf, respectively. Whether you’re sculpting the brilliance of your audio, enhancing midrange presence, or commanding the depths of your bass frequencies, TreBande does it all with the authenticity of a classic mixer equalizer.
Was ist eigentlich mit diesen ganzen Pluginmakern los? Unter macOS lassen sich die Regler nicht bedienen, geht nur numerische Eingabe. WTF?
Doof. Bis auf den Hiss-Knopf, der natürlich unerlässlich ist, wenn es mal lecker rauschen soll. Aber doof deshalb, weil man seine Ausgangslautstärke nicht frei einstellen kann (wie es z.B. beim ebenso einfachen wie kostenlosen Voxengo TEQ-421 möglich ist). Jeder größere Dreh verändert daher hörbar den Pegel im Mix. Oder hat er "Auto-Gain"? Dann will ich nichts gesagt haben.
Wobei Teile mit nur sehr wenigen Knöpfen natürlich grundsätzlich erstmal eine gute Sache sind, sofern die Knöpfe das Richtige tun.
Puh, der is glaub wirklich kaputt, ändert den Peak mit Oversampling (bzw. scheint nur mit 4x Oversampling korrekt zu laufen).
Was der 'high shelf' macht kommt mir auch sehr seltsam vor (hier nicht zu sehen).
