Bitwig Update-Thread
160dB
Da die Jungs von Bitwig ziemlich fleißig sind und immer wieder neue Updates raus bringen, hier der passende Thread um sich auszutauschen ;)
Die aktuelle Version ist Bitwig 1.3.4.
Changes in Bitwig Studio 1.3.4
Released on 27.11.2015.
FIXED Crash when changing buffer size in preferences.
FIXED Possible to create a feedback loop in a project by copying a dynamics device receiving from a track group into one of the tracks in the group.
FIXED Duplicating multiple audio events across multiple clips with time selection only duplicates last audio events.
FIXED Hardware Instrument device is not letting the sound thru after you open the project until you see the device itself or trigger a note in this track.
FIXED Recorded notes were sometimes assigned the wrong pressure value if the controller never sent a poly pressure event on that key.
FIXED Quit commad gets disabled on OSX after invoking once and choosing cancel in project save dialog.
FIXED Arranger object snapping should be off by default.
FIXED Mouse cursor sometimes does not reappear after moving automation point on OSX.
hat sich erledigt
Version 1.3.5 ist da.
Changes in Bitwig Studio 1.3.5
Released on 03.12.2015.
FIXED Dragging clip end in track note editor enables looping instead of just extending the clip end.
FIXED Icon that indicates launch quantization on clip loop bar is invisible when loop region is not selected in an unlooped clip.
FIXED If you have only one empty project (tab) open, save the project and immediately create a new project, the previous one will close.
FIXED Dragging a track from the browser that contained a VST into empty project after fresh startup would not load the plugin due to missing plugin state.
FIXED Controller API: device.addPresetCategoriesObserver/addPresetCreatorsObserver are not updated correctly.
FIXED Engine crash when switching documents.
FIXED VST window size is wrong in Melodyne 4 beta version on OSX.
FIXED Dragging notes from multiple clips in arranger with copy modifier will copy some notes and move others when dropping onto an existing clip.
FIXED Volume, pan and CC automation should follow clips when dragging to other tracks if follow clips is active (currently only does so if device chain is identical).
FIXED 32bit plugins with carbon windows don't open their window on OSX 10.11.
FIXED Removing stop button from clip slot should also remove record button.
FIXED Named device cursors should be updated to an existing device if possible when deleting a device.
FIXED Regression in 1.3.4: mouse cursor sometimes disappears on OSX.
FIXED Arpeggiator plays a full note when the gate is at 0%.
FIXED Crash when changing velocities using pencil tool in audio event area of hybrid track.
FIXED When saving a project and changing the list of tracks/track groups in that project the browser would not update with the new list of tracks.
FIXED Mouse cursors don't look sharp on OSX computers with Retina screen.
FIXED If Preroll is active, clip launcher clips already record during the preroll time.
FIXED Loop marker for clips on the arranger are not shown in the correct place and moves when zooming in and out.
FIXED Searching for letters and numbers (e.g. "7A") in files would not find files that have that in their name.
FIXED Dragging a track out of a deactivated group hangs the engine.
FIXED Track header width might be different from state before saving after opening project.
FIXED Next actions on clip launcher don't work in some cases.
FIXED Transpose expression zoom-scrollbar does not line up with timeline content by default in audio editor.
FIXED Folded lanes in note editor do not line up with the headers in tablet display profile.
FIXED Synced LFOs are not perfectly synced.
FIXED Bug in OSX 10.11 LauchServices causes Bitwig Studio to start only once (added workaround).
IMPROVED Fold state for drum machine clips shows note name in front of the pad name.
IMPROVED Raised silence threshold used by auto-suspend of plug-ins, as it was below the background noise of several popular plug-in effects.
IMPROVED Add action to toggle the showing and hiding of all automation lanes on the arranger and shift clicking automation icon in track header changes for all tracks in its group track.
Eine sehr gute DAW mit sehr guten, motivierten Programmierern, vielen dank für alles was ihr derzeit gemacht habt.
Respekt!
Seit gestern ist eine neue RC-Version draußen.
Bitwig Studio 1.3.6 RC-1 is available for download on http://www.bitwig.com/download.html. Here is the list of changes:
NEW - Added Post Recording Actions to clip launcher which are activated after a specified duration has been recorded. This can be used to record clips of a predetermined fixed length as well as to record multiple takes automatically to multiple clips.
NEW - Implement Choke for the Drum Machine.
IMPROVED - Added support for track and instrument name metadata to MIDI file import.
IMPROVED - Improved WASAPI perfomance.
IMPROVED - Made pencil tool smarter - it now lets you move and extend notes/clips without having to switch to the arrow tool.
IMPROVED - Much lower memory usage and better overall application performance on OSX.
FIXED - Crash when changing drum machine preset for another preset using the popup browser and having previously selected a pad that does not have a chain in the preset selected.
FIXED - Muted clips are not visually distinguishable from unmuted clips in clip launcher.
FIXED - Creating a clip in the clip launcher using different time signature than 4/4 still creates a clip with 4 quarters duration.
FIXED - Controller API: crash when using device layer bank.
FIXED - Free running automation is not shown correctly in content preview section of launcher clips.
FIXED - When there is a long list of items that needs to be scrolled in a menu it is not possible to select menu items using touch that are not visible.
FIXED - When importing MIDI files the clip length should be calculated from the content instead of from MIDI metadata.
FIXED - Rare crash when deleting a track or moving it out of it's group.
FIXED - On Linux the window shifts down by the size of the title bar each time the application is started.
FIXED - Zoom to fit leaves too much space in timeline editors.
FIXED - Exporting MIDI file should ignore muted notes.
FIXED - Dragging a track from one project to another that referered to a sample that was collected and saved on a different machine in the source project would not find the samples when dropped in the destination project.
FIXED - Notes in drum MIDI files that have zero length should be interpreted as 16th when importing into Bitwig Studio.
FIXED - Effect track is called audio track in context menu.
FIXED - Projects with editors set to triplets don't show correct value in grid subdivision fields.
FIXED - Moving multiple continuous clips with "automation follows clips" activated creates unneccessary automation dots at the boundries of the clips.
FIXED - Undo history breaks if you move an automation point and hit the right mouse key while doing so.
FIXED - Instrument notes are not truncated at the clip boundry when consolidating.
FIXED - Controller API: Crash when creating named device cursors from onMidi callback.
FIXED - Crash if bouncing a track region in place and before the bounce has completed deleting the track.
FIXED - Moving notes by a tiny amount using the inspector creates lots of duplicates.
FIXED - Sometimes engine crashes on OSX when connecting to document.
3 Updates innerhalb von 4 Wochen! Chapeau!
Aber es bei mehr FIX als IMPROVE auch kein Wunder. Da scheint noch Vieles im Argen zu sein.
Das sieht doch anderswo nicht anders aus. Aber stimmt, wenn man solche Listen liest, könnte man denken, die entsprechende DAW wäre vorher nur ein einziger, großer, unbrauchbarer Bug.
Jaja, Cubugs! Hatten wir hier seinerzeit auch durchgekaut. ;-)
Ist bis jetzt ja erst die RC-1. Aber die offizielle 1.3.6 Version dürfte nicht allzu lang auf sich warten lassen.
So ist es. Nur geben nicht unbedingt alle Hersteller die Änderungen so detailliert an.
Seit dem Update auf 1.3.5 läuft bitwig bei mir nicht mehr ganz rund. Ganz doofe DAW.
...und chleudert den Purchen zu Poden!
passiert halt, liegt dann wohl auch an der jeweiligen Konfiguration. Ich gehe ja seit einer Woche mit Studio One 3 fremd (weil das Midiediting da doch reifer ist), aber Fazit was stabiler läuft, Bitiwg, Studio One chrasht bei mir. Der Fairness halber muss ich aber auch sagen, nur wenn ich u-he's als VST3 lade, da bietet Bitwig ja noch nicht mal Unterstützung für an.
Aber ich finde es wird mal Zeit für ein Weihnachtsupdate oder Neujahrsupdate mit massiv improvements, so dass ich mich über die freien Tage weiter mit Bitwig einarbeiten kann.
Das hast du jetzt nicht wirklich gesagt?
Das hast du jetzt nicht wirklich gesagt? :heul:
doch, ist leider so, das Potential von Bitwig ist immer noch unbestritten, aber beim Midiediting fehlen mir einige essentielle Erleichterungen die Studio One bietet. Bin grad am überlegen ob ich mal einen Vergleich schreibe oder aufnehme, nur die Zeit. Will Bitwig keineswegs schlecht reden, aber man merkt die Reife von anderen DAW in einigen Bereichen. Nicht das ich nicht glaube das Bitwig das spätestens mit der 2.0 Version mindestens ausgleichen wird. Auch Bitwig hat einige Vorteile gegenüber SO, aber wenn ich gewichte, dann ist für mich Studio One da in front.
Edit: Kaum sage ich Bitwig crasht nicht bei mir...siehe screen
Auf Mac ist es bisher nicht gecrasht. Mal das ein Plugin in die Sandbox läuft, aber nach starten der Audio Engine (1 Klick) wieder ok
Ich dachte ja bis eben auch, wegen Sandboxing sei Bitwig uncrashable. Huch! ;-)
Introsong
Introsong
Introsong
Dimitrirec
Dimitrirec
Dimitrirec
Souljacker
Souljacker
Souljacker
