Studio One - Version 6.1.2 Release Notes (May 25, 2023):
  • Ersteller Lacunaflow
Lacunaflow
Lacunaflow
Influencer
Teammitglied
Ostfriesland
The following issues have been fixed:
● Selected layers not playing back initially after recording takes
● [Ampire/Pedalboard] Pitch Shifter does not read automation
● [Automation] Pencil Tool shows inconsistent behavior with Cmd/Ctrl key
● [Custom Colors] Color palette hides behind context menu
● [Custom Colors] Color pop-up in channel editor has no color selector
● [Custom Colors] Preset save dialog hidden behind color palette
● [Presence XT] Truncated instrument text description
● [Pro EQ³] Certain LLC settings may interrupt audio rendering
● [Pro-EQ³] Wrong latency reported when LLC filter is used in High Quality setting
● [Pro-EQ³] Threshold settings not saved in dynamic mode
● [Score Editor] Choosing notes in step record may add unwanted rests
● [Score Editor] Lyrics are not properly aligned to notes with certain values
● [Show Page] Certain sections do not work in Performance View
● [Start Page] Potential crash when clicking on a Song in Songs tab
● [Sync Points] Splitting an Event doesn't create an additional Sync Point
● [Track Presets] Instrument tracks don't connect to inputs from inserts of other tracks
● [Track Presets] Multi-outs may load in wrong order
● [VST2] Offline mode not reported correctly to plug-ins on bounce
● [Windows] Downgrading Studio One can lead to scripting errors
● Mono tracks can no longer be inputs for other mono tracks
● Track Notes cannot be enlarged after reducing track controls to smallest width
● Clip Gain Envelope with sudden changes adds unwanted fades
● Crash on transforming Audio Track back to Instrument Track with pattern
● Degrading performance while instantiating plug-ins in certain situations
● Dragging instrument parts to Chord Track not working properly in certain situations
● Input controls missing in Inspector when mixer is closed
● Instruments don't follow bus hierarchy when inserted via command
● Panning no longer works for instruments in Low Latency Monitoring path
● [Multi Instrument] Part Automation (Modwheel, Sustain Pedal, etc.) ignored in mixdown
● Plug-in automation appears off visually after opening song
● Potential crash on processing delay compensation
● Potential crash when editing transposed audio event during loop playback
● "Select All" selects lyrics of Arrangement and Scratch Pad
● Sidechain input lost after transforming Instrument to Audio Track and back
● Update check not working for external Language Pack from PreSonus Exchange
● Visual representation of notes disappear when changing timebase
