Isse gut?Count me in.
Deals gibt es selten!
Vocalstrip hätte ich gerne im Deal.
Ist mein 4. SSL
When most people think of SSL, one word comes to mind—punch. The SSL compression sound is arguably the most emulated in history, with scores of plugins and hardware devices claiming to mimic the sonics of the famed SSL G Console Buss Compressor. Surprisingly, while the Native Bus Compressor is absolutely stellar, it hasn't been my most used dynamics tool from the bundle. I found the X-ValveComp to be a truly pleasant surprise here and by far the most flexible dynamics tool available in the V6 Native suite.
The X-ValveComp—in contrast to the Native Bus Compressor, which directly emulates the original G series hardware, with no updates—is a thoroughly modern compressor and dynamics tool, offering Peak/RMS detection circuits, parallel blend controls, and a dual HPF/LPF internal sidechain, all of which are highly valuable to producers of Hip-Hop, Pop, Electronic, or any bass-heavy genre. In my testing, the X-ValveComp quickly became my go-to channel and buss compressor when I was looking for that familiar SSL punch and glue with a bit of a modern twist; the plugin sounds absolutely phenomenal, and there are movement and groove you can create using proper attack and release times that are precisely reminiscent of working with real SSL hardware. X-ValveComp is one of the more natural sounding compressors I've found to date, and it just makes everything you put through it sound phenomenal. Plucks, bass leads, drums, and vocals all sit vastly better in the mix with the X-ValveComp, and it's the standout plugin of the bunch in my book. While the Bus Compressor is great, I find the lack of an internal sidechain high pass filter to be a dealbreaker for Hip-Hop and Electronic tracks; unless you're really after a pumping master where the kick is triggering substantial compression, it's hard to get as modern of a sound as other SSL emulations provide.
Bin auch versucht den SSL x-valvecomp zu kaufen...Ich passe. Hab genug Kompressen, die ich nicht benutze.
Die Knöpfe werfen schöne Schatten.
Die Knöpfe blitzeln so schön an den Rändern, sehr plastisch. Solide SSL Qualität eben.
Da ist die Versuchung groß.
