mkzwoo
SSL Guitarstrip & Harrison Bass Flow Bundle gibt es bis zum 04. September 2023 bei Thomann zum Preis von 44,00 Euro anstatt 475,99 Euro...
SSL Guitarstrip is your new go-to processor for electric, acoustic and bass guitars. Providing 4 carefully tailored guitar processing modules, Guitarstrip is packed with useful tools for crafting the perfect guitar tone at both the pre-mix and mixing stages.
Featuring two classic analogue drive emulations – guitar amp and bass amp – Guitarstrip's DRIVE module allows you to easily add overdrive and grit to your guitar and bass DIs, tame harshness, or electrify your acoustic guitar recordings. Use the BOOST, PUNCH, EDGE and SHAPE controls to sculpt the added harmonics, and the DRIVE MIX control to dial in anything from trashy distortion to subtle saturation.
Guitarstrip also provides a dedicated COMPRESSOR section with 5 preset response characteristics to quickly tame levels or add punch to your guitar tracks. Use the intuitive PHASE CORRECTION module to identify phase issues between multiple recordings and correct them using the DELAY, PHASE INVERT and ALLPASS filter. By setting the ALIGN TO mode. You can even repurpose the phase correction module delay as a quick-and-easy way to add stereo depth to a mono signal.
Make your bass tracks more than just a collection of sounds, but a true expression of your artistic vision. The Harrison Bass Flow plug-in is a sophisticated tool allowing you to easily sculpt bass tones and elevate low-frequency content in your mix.
Bass Flow is an all-in-one bass processing suite complete with 4 internally routable mixing elements giving you the ability to rearrange the order of the processing to match your workflow perfectly. It also has input and output controls to ensure your levels are exactly where you need them. The results are quintessentially Harrison: effortless, smooth and transparent.
CRAFTING THE PERFECT GUITAR TONE
YOUR COMPLETE BASS PROCESSING SOLUTION
SSL Guitarstr & Harrison Bass Flow
SSL Guitarstrip and Harrison Bass Flow Bundle (ESD); Plugin-Bundle; zwei Spezialwerkzeuge zur Bearbeitung von Gitarren- und Bassspuren; enthält SSL Guitarstrip sowie Harrison Consoles AVA Bass Flow; SSL Guitarstrip verfügt über vier Effektmodule zur...
€44,00
www.thomann.de
