REAPER 5.97
sts
v5.97 - February 21 2019
  • + ARA: support for ARA2-compatible plugins
  • + ARA: support for importing notes and tempo from plugins into project, or exporting as MIDI
  • + Actions: allow removing FX chain actions
  • + Automation: handle empty automation items more gracefully [t=217307]
  • + Automation: fix crash when duplicating empty automation items via region copy [t=212401]
  • + Control surfaces: add action to reset MIDI control surface devices
  • + Control surfaces: actions for next/previous track update control surface offsets [t=184004]
  • + Joysticks: fix joystick support [p=2081611]
  • + Linux: do not show (unused) video output colorspace options
  • + Linux: fix crossfade window glitches [p=2083685]
  • + Linux: fix project bay menu issues [p=2083685]
  • + MIDI editor: allow resizing right edges of notes down to note insert size if lower than grid size
  • + MIDI editor: fix possible crash when editing notation
  • + MIDI editor: obey note insertion length when in measure-grid mode [p=2072523]
  • + MIDI editor: event filter fixes and tweaks [p=2089513]
  • + OSC: fix support for s/track/x/name setting
  • + OSC: fix unreliable setting of marker/region information by timeline-index
  • + OSC: support modifying/creating markers/regions by ID, using /region_id/@/time and /marker_id/@/time etc
  • + OSC: support writing marker/region values
  • + Performance meter: auto-resize text areas to configured view options
  • + Performance meter: optionally display video load
  • + Project bay: add position column for source media and media items
  • + Project bay: allow dragging complete (not trimmed) media into the media items tab
  • + Projects: add actions to save copy of project (optionally prompting for new filename)
  • + ReaComp: add pre-fader feedback detector mode
  • + ReaComp: deprecated non-fully-functional AA support, hidden when not used
  • + ReaComp: improve ratio/attack/rms slider curves and display precision
  • + ReaScript: fix MIDIEditor_GetSetting_int [t=212449]
  • + ReaScript: EEL2 scripts support //@gmem=sharedMemorySegmentName starting line in first 100 lines of code (also shares with JSFX)
  • + ReaScript: add reaper.gmem_attach()/gmem_read()/gmem_write() to Lua for interacting with JSFX/Video Processors/EEL2 ReaScripts gmem[] segments
  • + ReaScript: support UTF-8 characters in os.remove()/os.rename() on Windows
  • + ReaScript/JSFX: add gfx.a2/gfx_a2 for creating transparent images
  • + Stretch markers: add new "transient-optimized" and "no pre-echo reduction" stretch marker modes
  • + Stretch markers: add project setting for stretch marker mode
  • + Stretch markers: improve timing of timestretch ramps with elastique and Rubberband Library[t=204269]
  • + Track FX drag: update mouse cursor when changing modifiers
  • + Tempo map: fix importing initial time signature from MIDI tempo map
  • + Theme: fix retina vs HiDPI inconcistency relating to label margins
  • + VST: do not deactivate VST3 plugins before changing IO buffer information
  • + VST: flush VST3 buffers on stop without resetting other plugin state
  • + VST: inform plugins of project loop selection regardless of playback state
  • + VST: report loop points to plugins even if project repeat is disabled
  • + VST: restore pre-5.9x reset-on-stop default behavior for ET-200, FA3, Vienna Ensemble
  • + Video: sort and reorganize preset names into categories
  • + Video: add new presets including Color Peeker, Decorative Oscilliscope, Decorative Spectrum Analyzer, RGB Histogram, Resize to Project Settings, Screensaver, Frame Rate Decimator, RGB Shadow/Midtone/Highlight, Apply Track FX Only Where Track Has Video Items [p=2073314], Vertical Wipe
  • + Video: improve various built-in presets
  • + Video: improve Chroma-key presets, add separate RGB/YUV versions
  • + Video: add JSFX video sample peeker which can provide audio samples to Decorative Oscilliscope/Decorative Spectrum Analyzer presets
  • + Video: add experimental performance tweaks and information to video window menu
  • + Video: add experimental decoder prefetch support (improved multiprocessing, improved reverse video playback performance when enabled)
  • + Video: add option to show green frames for underruns, rather than previous frame
  • + Video: add option to disable rendering cache for all media/video FX (can be used for low latency interactions)
  • + Video: avoid re-rendering video frames when tweaking parameters during playback
  • + Video: better preview behavior when slip editing items
  • + Video: improve monitoring FX performance during underruns/seeking, playback recovery after CPU overutilization during normal playback
  • + Video: improve preview behavior when scrubbing backwards continuously
  • + Video: always force rendered videos to be even in dimension
  • + Video: do not process any video when rendering audio-only
  • + Video: do not run video processors in monitoring FX chain while rendering
  • + Video: increase maximum parameter count to 24
  • + Video: parameters can now be specified without indices for convenience
  • + Video: add processor support for gfx_a2, which can be used to control RGBA alpha-channel writing
  • + Video: add processor functions: gfx_getpixel(), input_get_name(), on_parameter_change(), time_precise(), ui_get_state(), fft()
  • + Video: improve gfx_evalrect() (can take flags to process right-to-left, vertical, third source for 3-way blends, initialization code, returns -1 on error, add restrictions to processor code)
  • + Video: improve input_info() to not clear project_w/project_h if they are passed as parameters and input is not present
  • + Video: support //@gmem=sharedMemorySegmentName (also shares with JSFX's options:gmem=)
  • + Video: fix RGBA chromakeyed blit [t=213118]
  • + Video: improve internal colorspace management logic (reduction of excess colorspace conversions)
  • + Video: improve knob behavior relating to mousewheel, step sizes, and undo/redo
  • + Video: fix VLC decoding to RGB [t=215295]
  • + Video: fix ffmpeg hang when seeking some old miniDV .avi files
  • + Video: improve VLC/ffmpeg decoding behavior near end of file [p=2069421]
  • + Video: improve DirectShow output performance
  • + Video: fix refresh issues with linux or Windows/BitBlt() output
  • + Video: optionally send CC events on video window mouse drag (once option enabled, right click in MIDI learn window to assign)
  • + Video: output colorspace preference no longer affects processor rendering pipeline, only final display stage
  • + Virtual MIDI keyboard: do not adjust center position in response to UI sizing [t=209001]
  • + WALTER: fix HiDPI extended mixer mode setting [p=2075538]
  • + macOS: switch to newer development toolchain for release (improves video playback on large monitors and fixes AUv3 issues on 10.14)
  • + macOS: removed PPC bridging support
  • + macOS: workaround for NSWorkspace race condition when launching external editors after open-copy [t=214818]
Generated by X-Raym's REAPER ChangeLog to BBCode
Gerade gesehen, Reaper hat ARA. Cool
Habs mit Melodyne probiert. Funzt wirklich.
Bin gespannt, was nach 5.99 kommt. Vielleicht 5.100? SCNR
Ich glaube (fast) jeder freut sich wenn da irgendwann mal eine 6.0 zum Download steht. Fairerweise muss man aber auch sagen: Das was Justin & Cockos pro Update da an Fixes und oft auch an wirklichen Features raushauen, wäre bei anderen Herstellern nicht nur ein X.99x sondern ein X.x. Als Reaper-User sind wir da schon verwöhnt ;)
Von daher: Ich freue mich auch auf eine 6.0 irgendwann, bin aber selbst mit den "kleinen" Sprüngen was die Versionszahl angeht sehr zufrieden.
Ich bin eher neuigierig was GRANDIOS-GIGANTISCHES kommen muss, wenn mal eine neue Major-Version ansteht...
Super, mein Lieblingsupdate!
1. ARA
2. Der Bug im Virtual Keyboard wurde gefixt. Und zwar nur, weil ich Justin noch mal eindrücklich Bescheid gesagt hab:
t=209001 ;-)
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
mkzwoo
Kosaken-Kaffee
Kosaken-Kaffee
