Hare Krishna - Er ist da !
  • Ersteller Ersteller InnerNoize
I
InnerNoize
Endlich ist er da!
Der Devine Machine Krishna [g=77]VST[/g]-Synth...:)
Krishna Synth Feature List :
Frame Oscillator:
* New Synthesis System (Frame Oscillator).
* Sound/Speech/Waveform import with Frame Analysis Technology (F.A.T.).
* Full Control Over Frame Rate and (re)Animation of imported sounds.
* Variable PWM Effect.
* Mirror Effect.
* Mirror Quantized Effect.
* Repeat Effect.
* Bit Reduction Effect.
* Lo.fi Effect.
* Squarer Effect.
* Exclusive Draw Screen.
* 9 Sizable Draw Tools: Sine, Triangle, Ellipse, Square, Line, Noise, Harmonic, Smooth and Pencil.
* Several interpolation modes.
* Volume and Pan control.
* Coarse Control(-36/+36 semitones).
* Fine Tune Control (-50/+50th of a semitone).
* User friendly Import Menu.
* Batch Import.
Analog Model Oscillators
* 2 Analog Model oscillators.
* 5 Oscillator shapes on both Analog Oscillators: Saw, Sine, Square, Triangle and Noise.
* Old [g=365]synthesizer[/g] defect emulation for each oscillator.
* Desync for each oscillator.
Filters / Post Oscillator Synthesis
* 3 Fat Analog Model Filters (Low Pass, Band Pass, High Pass).
* FM Synthesis.
* RM Synthesis.
* AM Synthesis.
LFOs
* 5 LFOs, each with 3 bipolar sends.
* Free drag and drop assignation to any control on screen.
* 108 internal modulation destinations.
* 16 external [g=32]MIDI[/g] OUT modulation destinations.
* 11 shapes: Saw, Inverse Saw, Triangle, Sine, Chaos, Square, Noise, Log, Inverse Log, Triangle Log and Ellipse.
* 6 Drawable LFO Step Sequencers : Shapes: Simple, Ramp, Saw, half-Saw, Soft, fine.
* Speed Settings: from 32 Bars to 128th with dotted and triplets, and up to note frequency multiples.
* LFO Phase Control for each LFO.
* Unipolar/Bipolar switch for each LFO.
* LFO per voice (Polyphonic), or synced (Monophonic) for each LFO.
* Perfect Sync of LFOs with host tempo and timecode.
* LFO Speeder knob: Turn up all LFO rates live with a single control .
* Feedbacked LFOs: LFOs can control LFOs/AHDSRs.
* Knob Movement Recorder: get control movement recorded into the LFO.
* LFO Visual [g=94]Feedback[/g]: See LFO output directly on the destination.
* LFO Visual Routing: any control affected by LFO shows up in green.
Envelopes
* 3 Envelopes with Attack, Hold, Decay, Sustain, Release.
* Five response modes: [g=21]Velocity[/g], Key, [g=21]Velocity[/g] Sync, Key Sync,[g=21]Velocity[/g] To Decay.
* Envelope discreet parameters: time in samples of the "zero ms" attack/release.
* [g=94]Feedback[/g] AHDSRs: AHDSRs can control LFOs/AHDSRs.
* AHDSR Visual [g=94]Feedback[/g]: See output of AHDSR directly on the destination
* AHDSR Visual Routing: any control affected by AHDSR shows up in yellow
* Auto-Zoom Envelope to Screen Adjust.
* Show all envelopes by using soft transparency.
Note Step [g=70]Sequencer[/g]
* 16 Steps [g=70]Sequencer[/g].
* 128 Pattern Memories.
* Step Size from 1 to 16.
* +2/-2 Octave Control for each step.
* Slide Control for each step.
* [g=21]Velocity[/g] Control for each step.
* 2 Randomizers (Intelligent/Chaotic).
* Speed Settings: from 32 Bars to 128th, with dotted and triplet.
Effects
* Tube Emulation with customizable cabinet size and frequency.
* High Quality Effect Chain.
* [g=36]Phaser[/g].
* [g=104]Flanger[/g].
* [g=52]Chorus[/g].
* Delay.
* Reverb.
* Several Models of [g=36]Phaser[/g], Flanger, [g=52]Chorus[/g] and Delay.
* Perfect sync of effect parameters with host tempo and timecode.
* Effect Preset Managers including dozens of Effects Presets.
Play Modes
* Legato.
* Mono.
* Unison using from 1 to 16 note (user selection).
* Unison Pitch detune (added to each extra unison voice).
* Unison Phase delay (same).
* Unison Random Pitch detune (same).
* Unison Random Phase delay (same).
* Unison Master Level Compensation to avoid output saturation.
* Free polyphony per preset: from 1 (mono) to 16.
* Time or Distance [g=22]Portamento[/g].
* [g=22]Portamento[/g] option to 'stay' on last note or not.
* Build-in Hold implementation.
* Distinct Up and down values for Pitchbend range.
* 16 voice polyphony.
* Preset Master Tuning.
* Global Master Tuning.
[g=32]MIDI[/g] Features
* Advanced and visual [g=32]MIDI[/g] Learn Mode.
* [g=32]MIDI[/g] Learn Edit Screen.
* [g=32]MIDI[/g] Controller number and [g=190]Channel[/g] Edit.
* [g=32]MIDI[/g] Learn invertable min and max Edit.
* [g=32]MIDI[/g] Intelligent Random Mutate.
* [g=32]MIDI[/g] OUT Full Implementation.
* [g=32]MIDI[/g] out controls on [g=190]channel[/g], Controller number, minimum and maximum output values.
* PANIC support
Preset Management
* Preset Manager.
* Managing functions: Save, Save As Variation, Replace, Move to Category, Delete.
* Preset Category reflecting Folder hierarchy on Hard Drive.
* Easy to Read List.
* Random Preset Generator.
* Mini Preset Browser.
Misc.
* Big Parameter Read-out in the central screen.
* Intuitive 3D user Interface.
* On/Off Switch For every Module.
* Option Screen with clear categories.
* Preset Options (Saves in Preset).
* Global Options (Saves on Exit).
* Visual Modulation Routing.
* 1146 presets.
* 2132 movie files to be used directly into Frame Oscillator.
Krishna Synth Presets Content :
1146 Presets come with Krishna Synth, as following :
[g=118]Bass[/g] Acoustic : 36
[g=118]Bass[/g] Distorted: 16
[g=118]Bass[/g] Electro: 103
[g=118]Bass[/g] FX: 21
Electrical Guitars: 18
Keys: 149
Leads: 173
Pads: 215
Retro Games: 44
Sequences: 130
Sound Effects: 136
Strings: 11
[g=90]Voices[/g]: 26
Winds: 7
World: 61
Movie Files Content (For Frame Oscillator OSC 1)
2132 movie files have been processed at maximum settings. They all can be used directly in oscillator 1 (Frame Oscillator), to give as many different soundings for this oscillator.
_____
online version in 12 payements (12 monthes) : 19 euros per month
online version in 6 payements (6 monthes) : 35 euros per month
online version purchase : 199 euros
online version+boxed version : 259 euros
_____
Beim testen der Demo bitte nicht erschrecken, hat es der Entwickler mit seinem periodisch eingestreuten Störgeräusch doch "etwas" sehr gut gemeint.
Mein bisheriges Fazit nach knapp 2 Stunden intensiven schraubens:
Der Krishna macht einfach Spaß und stellt meines erachtens ein absolutes "must have" Instrument da.
Er biete tolle inovative Features, gepart mit einer sehr einfachen und intuitiven Bedienung und einem tollen Klang.
