suboptional
v5.32 - January 17 2017
- + Actions: ignore item/track/envelope focus in 'Item: Select all items' [t=186406]
- + API: add PCM_Source_GetPeaks, GetMediaItemTake_Peaks
- + API: add an additional sorting step to MIDI_Sort and other functions that sort MIDI from API [t=184459]
- + Automute: fix auto-mute detection on high channels when multichannel track metering is enabled
- + Configuration import/export: support web interface pages
- + Free item positioning: reposition items after dragging in new media items or gluing [t=183298]
- + JSFX: improve retina/hidpi support for various analysis plug-ins
- + MIDI editor: add action to set length for next inserted note to grid
- + MIDI editor: add mouse modifiers to insert note ignoring scale/key [p=1776708]
- + MIDI editor: add option to edit velocity only when mouse is within velocity bar [t=185372]
- + MIDI editor: add some notation actions to piano roll note context menu
- + MIDI editor: better support for cut/copy/paste of MIDI events from/to multiple tracks
- + MIDI editor: display notation data in a lane in the piano roll
- + MIDI editor: edit text/sysex events on right-click, rather than delete
- + MIDI editor: faster loading of very large .reascale files
- + MIDI editor: fix display of captured CC event value
- + MIDI editor: fix various cases when note edits extend the media item
- + MIDI editor: ignore double note-on or note-off messages when opening editor
- + MIDI editor: improve .ins (patch/bank) file reading [t=185235]
- + MIDI editor: respect event filter and mark selected events in raw MIDI viewer window
- + MIDI editor: show toolbar button feedback for actions to set next note length
- + MIDI editor: support loading CC names from note name map
- + MIDI: don't play back notation for muted notes
- + MIDI: preserve muted events during glue
- + Metering: add preference for pre-fader track metering with action to toggle
- + Mouse: add option to improve knob behavior with pen/tablet/absolute pointing devices
- + MusicXML: fix parsing of elements containing HTML entities [t=185242]
- + Notation editor: add "remove" button to tuplet dialog
- + Notation editor: add action to identify chords on grid
- + Notation editor: add support for manually entering chord notation
- + Notation editor: add support for more ornaments and techniques
- + Notation editor: add whole note trill ornament
- + Notation editor: autodetect smaller triplets before longer ones [t=185653]
- + Notation editor: draw ties and phrases/slurs above/below notes when note voice is set
- + Notation editor: draw voiced rests farther from the staff
- + Notation editor: edit tuplet brackets when running actions to change or select note voice [p=1776813]
- + Notation editor: fix chord notation sometimes not being visible immediately after entering
- + Notation editor: fix crescendo/diminuendo that spans multiple rows
- + Notation editor: fix erratic tuplet bracket positioning on grand staff [p=1775774]
- + Notation editor: fix potential hang in MusicXML export [t=185288]
- + Notation editor: fix setting one half of grand staff to +/- 8/15 va/vb (up or down one or two octaves)
- + Notation editor: hopefully less intrusive edit cursor drawing
- + Notation editor: improve chord detection
- + Notation editor: improve tuplet autodetection
- + Notation editor: include user-defined chords (loaded from MIDI editor key snap dropdown when identifying chords
- + Notation editor: increase space between staves
- + Notation editor: notation events follow notes rather than preceding, may affect user scripts/plugins that read notation messages
- + Notation editor: prevent grabbing the note edge when the note is very small
- + Notation editor: prevent hang when identifying chords with large .reascale file loaded [p=1775703]
- + Notation editor: support "chart" clef (no notes, just beat markings and chord/other notation)
- + Notation editor: support copying/dragging notes to another staff row or track
- + Notation editor: support entering arbitrary track and note notation/ornaments via text entry (example: 0xE5D2 for "lift", see smufl.org)
- + Notation editor: support per-note text ornaments
- + Notation editor: support slide, bend, and hammer-on/pull-off as types of slur
- + Notation editor: support track notation that applies to a length of time (drag right hand edge of notation)
- + Notation editor: tuplet dialog remembers previous settings
- + Notation editor: when creating tuplets in a voice, set selected note voice to match even if not modifying note positions [p=1777017]
- + Peaks: add peaks display settings window
- + Peaks: add spectral peaks option
- + Peaks: fix issue where rebuilding peaks would not rebuild when multiple peaks files are present
- + Peaks: sinc interpolation display option for sample-level peaks
- + Project tabs: allow setting media online when switching tabs and background projects are playing
- + ReaFIR: add new improved default quality mode (previous behavior is now legacy 2007-2016 mode)
- + ReaFIR: decreased CPU use
- + ReaScript: allow up to 32M memory slots for each EEL script
- + ReaScript: ensure IDE is not completely offscreen when opening
- + Recording: fix issue when recording in background tab and record preroll in the active tab
- + Recording: fix varispeed item recording quirks
- + Recording: fix corner case with time selection autopunch recording [t=186068]
- + Transport: do not apply unedited text fields when enter is not pressed [t=185813]
- + Transport: improve behavior when adding tempo markers from BPM field [t=185813]
- + Undo: include modified envelopes in undo states when modifying time map [t=186284]
- + Video: improve behavior of video processor bypass automation
- + Video: include fullscreen state in screensets
- + Video: restore fullscreen state on re-open if window not docked
- + WavPack: large file reading support
- + WavPack: upgrade to WavPack 5.0
- + Windows: configurable HiDPI behavior in prefs/general/advanced, new default behavior prevents plug-ins from enabling HiDPI
- + Windows: fix knob issues on Win10 HiDPI displays [t=168589]
- + Windows: improve knob behavior when adjusted from touch input
