RELAB VSR S24 - Reverb
  • Ersteller electronative
electronative
electronative
Mit Ihrem LX480 haben die ja schon einen sehr guten Hall.
Das neueste aus dem Hause Relab heißt VSR|S24.
"VSR S24 is a faithful recreation of a very high-end sets of algorithms for both music and post productions.
The reverb excels at applying 'prettier than life' reverberation to many sources of a mix or complete stereo/multi-channel stems. It adds complex Early Reflections as well as uncorrelated diffused response to the signal.
VSR S24 is the first professional reverb with multiple selectable reverberation engines which can completely change the overall spaciousness, color and reverb characteristics to simulate any environment accurately.
Features:
• Extensive selections of Early Reflection patterns, ranging from studios to various concert halls
- Bathroom
- Theater
- Church
- Vienna Halls
- Etc.
• Customizable Early Reflection section
- Optional choice between 1st - 3rd order reflections
- Front/rear direction controls
• Selectable reverberation engines and characteristics
- True stereo operation
- Up to 5 engines with separate controls
• High precision calculations compared to the original
- Improved sound quality
- Improved filter precision calculations
- Improved frequency calculations
- Reduced noise
• Enhanced parameter range
- Extensive modulation range
• Customizable with sliders for HUE, color saturation, brightness, reflection amount and back lighting
http://relab.dk/vsr_s24.html
Werd ich auf jeden Fall mal ausprobieren.
Greez
Hmmm...
Die Betaversion kann man zwar herunterladen, aber es braucht ja noch die Ilok Authorisierung.
Da ist nichts zu finden, oder bin ich jetzt gerade unterzuckert?
Sorry, hatte ich vergessen :D
Contact beta@relab.dk to participate and try the new high-end reverb from Relab Development.
Ich habe mir das Ding gestern gezogen und per Mail auch die Autorisierung sehr schnell bekommen.
Erster Eindruck: Hammer!
Ich kann wirklich jedem Hallinteressierten empfehlen, das Ding mal zu testen. Es ist ganz offensichtlich ein Clone eines TC VSS Reverbs, wobei mir bei TC die Detailkenntnis fehlt um zu beurteilen, welcher Hall da genau modelliert wurde. Bei Gearslutz wollen einige den VSS4 erkannt haben.
Ich habe es bisher nur oberflächlich angetestet, aber ich kann schon mal sagen, dass die ERs herausragend kommen und sehr flexibel sind, während der Reverbtail dicht aber auch immer sehr klar und natürlich ist. Das ist schon sehr der Charakter, den ich mit einem guten TC verbinde, aber dazu sollen Leute mehr sagen können, die TC Reverbs besser kennen als ich.
Leider fehlt bei der Beta ein Manual, so dass sich vor allem die 5 unterschiedlichen Grundalgorithmen nicht von selbst erschließen. Das ist hier nicht einfach nur Hall, Plate und Room, dann wär's ja einfach. Auch da dürften TC Besitzer im Vorteil sein, ich halte mich da mal raus.
Ich fürchte nur, so ganz billig wird es wohl nicht werden.
Danke Dir, Rainer, das hört sich ja schon mal gut an!
Ich werds am WE auch checken.
Hast Du den mal mit anderen Reverbs verglichen, soweit das möglich ist?
Ich weiß, die VSS sind ja eher in der PostPro unterwegs, sollte sich aber für Musik gleichermaßen eigenen. Der LX480 Complete ist ja mit 400€ auch relativ teuer.
Ich hatte gestern Abend nicht die Zeit, ausführliche Vergleichstests zu machen und habe ihn nur mal auf ein paar Spuren geworfen, auf denen ich bisher Phoenix hatte.
Die beiden liegen m.E. qualitativ auf dem gleichen Level, haben aber unterschiedliche Charaktere. Die ERs sind beim Phoenix auch herausragend, aber beim Reverbtail ist der VSR24 flexibler und kann auch Charakter, das kann Phoenix nicht so gut, dafür hat EA ja auch den R2 im Programm.
Das LX480 habe ich in meinem Slate everything bundle, benutze es aber so gut wie nie, da ich den 224 von UA als "Charaktersau" bevorzuge. Das 480 ist cleaner, aber nicht clean genug, um es ganz modern klingen zu lassen, also das, was man heute mit einem Bricasti macht. Dafür habe ich in Software dann Phoenix und R2, so dass der LX480 bei mir immer durch's Raster fällt. Ich hätten mir ihn auch standalone niemals gekauft, er ist halt "Beifang" beim Slate-Bundle.
Ich kann aber mal schauen, ob ich heute Abend mal den LX480 anwerfen und ein paar Vergleiche machen kann.
Ich würde aber sowieso ganz grundsätzlich TC Reverbs nicht mit Lexicon vergleichen wollen, im Prinzip braucht man beide Halltypen ;)
Sehr cool, danke Dir. Bin echt gespannt.
Habe das VSR heute getestet.
Sound gefällt mir sehr gut!
Ein guter Mix aus "real space" und "bigger than life" digital reverb (Lex...)
Im Vergleich mit einem Smooth Room aus dem ValhallaVintageVerb scheint mir das VSR etwas mehr "Tiefe" zu erzeugen. Der Smooth Room klingt minimal breiter aber mehr nach 2D.
Die ER section gefällt mir sehr gut!
Modulation klingt gut und lässt sich gut einstellen.
Die GUI erscheint mir an manchen Punkten gewöhnungsbedürftig.
Sieht alles etwas unscharf aus (Beta?).
Crossfeed kann man nur über die "Advanced" Seite einstellen.
ER Decrease und ER Start sollte man vielleicht grafisch darstellen - so wie im Phoenixverb.
Hi Soften - ist vermutlich ein Hi damp (so wie ein air filter) , ist aber etwas unklar und recht subtil.
Den low mid hi - XOver readout finde ich nicht so gelungen.
Da die Parameter nicht unter den zugehörigen Blöcken stehen.
Eine A/B und undo/redo Funktion wäre ebenfalls schön.
Beim Preset Handling könnte man auch noch was tun... :)
Aber der Sound ist sehr vielversprechend !!!
Gibts bei euch schon was neues zu berichten bzgl. des VSR S24 ? - Weiß ansonsten jemand was da eigentlich im Modulations-Bereich passiert, mit so Einstellungen wie "left-right". Ich dachte eigentlich dass die Reverb-Tail in dem Fall da irgendwie von links nach rechts gepant wird, oder verhält sich das anders ? Im Manual ist das nicht erklärt.
Unglaublich wie sauber sich dass Reverb von Relab in den Sound einfügt. Ich kann nicht sagen, wann ich so ein extrem gut klingendes Hall Plug-in auf Software Basis gehört habe. Mir hat es wahrlich Schmetterlinge in den Bauch gezaubert - wenn da nicht der hohe Preis von 229 $ wäre.
Erinnert stark an das TC Electronic VSS3, was ja klanglich identisch mit dem System 6000 sein soll.
http://www.tcelectronic.com/de/vss3-native/
ImageGen.ashx
Ach, ich finde den Preis nicht hoch. Überlege mal was vor 10 Jahren Hardware Hall gekostet hat, bzw. was heute noch Hallmaschinen in Hardware gegossen kosten. Wir haben himmlische Hall-Zeiten heutzutage. Ja, der VSR S24 ist ein wirklich toller Reverb. Ich hab jedoch für mich entdeckt, daß der Lexicon PCM Concert Hall eigentlich genau dasselbe macht mit Piano, was das heißgeliebte Preset Large Premium Hall im VSR S24 macht, nur der Raumeindruck ist marginal anders, das Stereobild ist beim VSR leicht nach links verschoben. Mal sehen, vielleicht kauf ich irgendwann ja doch noch das Bundle mit dem 480L. Hab halt schon so viel, und die Baustellen sehen im Moment anders aus, als noch das 6. Hallplugin zu kaufen.
bitte löschen
Da gebe ich dir voll und ganz Recht, wir können echt froh sein das wir heute solche Möglichkeiten haben. Ich finde es auch immer wichtig das es einfach zu Bedienen ist, und nicht in eine Parameter - Flut endet.
