Motu M4: Gain Verlust bei Line out 3/4 direkt zurück in Line in 3/4?
  • Ersteller Alexander29
Alexander29
Ich hab bei einer Fehlersuche hinsichtlich Gain Verlust gerade bemerkt, dass ich ca. 4db Gain verliere, wenn ich (über einen Ableton External Audio Effekt, wo natürlich alle Gain Regler auf 0 stehen) das Signal bei meinem Motu M4 über Line 3/4 Out raus und direkt wieder in Line 3/4 Input wieder rein schicke. Diese EIn- bzw. Ausgänge haben ja keine eigenen Gain Regler daher nehme ich mal an das sollte eigentlich unverändert bleiben.
Hat jemand eine Idee oder dasselbe bei seinem Motu bemerkt?
Danke!
Nutzt du die symmetrischen Anschlüsse ?
@derspencer Ja, nur symmetrische Kabel und Anschlüsse
Mit In und Out von 1/2 versucht?
Der Motu Support sagt das sei normal:
Thanks for reaching out. This is normal. The input specification for the M4's input 3-4 is +18dBu. This spec is actually 6dB lower than the professional audio standard of +24dBu. In actuality, the 3-4 inputs on the M4 are going to be 6dB louder than the standard rating for pro level equipment. Here's why the inputs 3 and 4 on your M4 may seem too soft: +4dBu is standard nominal level for professional audio levels. Inputs designed for professional live or studio sound will have a very high "ceiling" before the nominal +4dBu signal will clip. The reason of this design, is to make the chance of accidental clipping very unlikely. Think of it as a safety feature. For example, you may be recording a mix of a band on inputs 3-4, feeding these inputs a nominal +4dBU signal. If the band starts playing much much louder, the input can handle an additional 14dB of gain before signal clipping and distortion occurs. On the more expensive MOTU products, you can boost the trim level of the line inputs should you want just a bit more control of them. Since the M4 is a more modestly price product (although very stellar in sound), the line inputs are fixed at +18dBu, a true professional spec. In other words, the results you are experiencing from the test being performed is normal.
@Ennui Danke, das wär auch meine nächste Idee gewesen, aber da es laut Motu Support normal ist, siehe oben, ist das Thema erledigt :)
BassExplorer
B
6K
YogiX
Y
9K
Kuno
Kuno
