terrablue
New Ultrasaw oscillators (PW controls detuning):
- 4 new oscs 'Hypersaw Vir 3x-9x' which can sound like the Hypersaw of the Virus
- New osc 'Supersaw JP' which has been inspired by the famous JP 8000
- New osc 'Supersaw clean' (same as above, but without disharmonic aliasing)
- New osc 'Supernoise' with a lush and creamy sound
- New osc 'Hypersquare 9x' with 9 detuned squarewaves
- New osc 'Hypernoise 9x' with a lush and creamy sound
New effects:
- Vocoder Pro is a high-end vocoder with 20 bands. The design is inspired by the legendary EMS 3000.
- Vocoder SVC has been inspired by the famous SVC 350.
New features:
- The effect parameters of all 4 insert effects can be modulated with the matrix. This can be used to create very unique sounds. Please note that not all possible routings make sense.
- Additional matrix target 'FX Mix' controls the dry/wet level of the insert effect
- Additional matrix targets 'FX Par1-4' control the effect parameters
- The new sound mode 'scientific' turns Electra2 into a precise signal generator
- The new sound mode 'LowCut 140Hz' cleans up the mix by removing low frequencies from Pads, Keys and Leads
- The new sound mode 'HighCut analog' simulates the muffled sound of analog synths and cleans up the mix by removing high frequencies from bass sounds.
- Additional patches which use the Supersaw OSCs: Electra 2.1 now ships with 1240 sounds
- 236 additional waveforms
Enhanced sound:
- The Vocoder effect has been replaced by an enhanced one
- Smart oversampling of the existing Ultrasaw osciallators
- More linear frequency response
- Replaced 'Reverb Hall' and 'Reverb Room' with better sounding algorithms
- High frequencies of 'Delay' and 'PingPong' effect
Enhanced GUI & interface:
- Mousewheel support for patch browser
- Better performance when patch browser is open
- Midi CC assignments are shown on top of the knobs
- Midi learn is more intuitive to use (right click on a knob)
- Menus are not longer closed automatically after 10 seconds
- Display of the new Ultrasaw oscs shows spread
- Switching synthesis mode does auto-set PW to a useful value
Further enhancements:
- Reduced RAM use by 30%. This allows to load 4 additional instances in 32 bit mode.
- Faster loading of patches.
- Reduced CPU use on patch loading.
Bug fixes:
- Fixed a problem with the LFO syncronisation in song mode which could appear in some hosts
- Fixed a rarely apearing crash after loading a patch and then selecting 'init'->'reset all'
- Fixed a problem with saving the midi learn configuration when sevaral instances were opened and closed at the same time
- Fixed a possible GUI glitch after loading a patch
- Fixed a possible crash which could happen with some very old hosts
- Fixed a problem that could happen if tone was routed in the matrix
- Background grid of step lfo was not displayed correctly
- Fixed a bug in 'Loudness' where high frequencies were boosted in a slightly incorrect way
Changes:
- Renamed 'Loudness' to 'Dynamic loud'
- Renamed 'Bass boost' to 'Dynamic bass'
- Renamed 'Analog' to 'Bass boost'
- Renamed 'Psychoacoust.' to 'Loudness'
New effects:
New features:
Enhanced sound:
Bug fixes:
Changes:
